Question about R34 transfer case and rear axle
Old Nov 18, 2010 | 02:30 PM
blueroo's Avatar
I'm in the process of doing a custom build. I was wondering if the transfer case and rear axle from the R34 could be used with a different transmission such as a Lenco for example. The reason I ask is I found a picture of the transmission and transfer case together but there appeared to be two fluid lines running from the t-case to the trans and I wasn't entirely sure what they are for.
As for the rear axle I read something about a fluid lock up or something and I wanted to know if this was tied into the transmission or not
Highclass
Apr 29, 2015 01:55 PM
Driller Mike
Jun 25, 2014 09:54 PM
AkuKiri666
Jan 21, 2010 10:51 AM
