power to rear wheels in a R32 GTR
Is there an electronic controller that allows you to send more power to the rear than the fronts of the R32 gtr? If there is let me know thanks
yes there is. its called a torque splitter. do a search on ebay and the likes and you should find one ,around a 100 quid i think. turning off the key and back on while rolling should put the 4 wheel drive system into 'fault' mode and send the power to the rears until you come to a momentary stop. it'll then go back into 4wd and the 4wd light will go off the dash.
There Is a 4wd fuse under your right knee ...pull it out when your stationary and then you will have 2 wheel drive ...
Get that arse end out man Gaz |
Be carefull if you are putting it on a 2wd dyno. The center diff has a small preload. I think it is like 5 percent or less. But this can cause the center diff to over heat on the dyno.
yeah, i was going to say, this sounds like a good way to put too much stress on old parts
