M7 Competition Type R Oil Cooler Kit (Universal type)
1. During extreme conditions, especially in high-horsepower output vehicles, the oil can breakdown chemically causing inadequate lubrication resulting in damage to the engine and turbo. 2. M7 Oil Cooler Kit was designed to effectively maintain oil temperatures at acceptable parameters to prevent viscosity breakdown. 3. M7 Oil Cooler's exclusive "tube and fin" designed cores are full, high-grade high-heat transferable aluminum with larger capacity end-tanks which allow more oil to bypass and cool efficiently. 4. M7 Oil Cooler Kit exhibit superior thermal efficiency along with the versatility of being relocated. Each kit comes with fittings, steel-braided lines and all hardware necessary for installation. M7 Code: COC-7 Application: Universal Core size: L300mm x H173mm x W50mm Fitting: #10 http://a2.sphotos.ak.fbcdn.net/hphot...14174076_n.jpg http://www.facebook.com/l.php?u=http...ml&h=SAQHsvhUx |
