Nissan GT-R Features & Specs
Specifications Engine VR-series twin-turbocharged 3.8-liter V6. 480 hp @ 6,400 rpm. 430 lb-ft torque @ 3,2005,200 rpm. Dual overhead camshafts with variable intake-valve timing. Cast aluminum cylinder block with high-endurance/low-friction plasma-sprayed bores. IHI twin turbochargers, one per cylinder bank. Pressurized lubrication system with thermostatically controlled cooling. Drivetrain ATTESA ET-S All-Wheel Drive (AWD) with independent rear-mounted transaxle integrating transmission, differential and AWD transfer case. Rigid, lightweight carbon-composite driveshaft between engine and transaxle. Electronic traction control plus 1.5-way mechanically locking rear differential. Vehicle Dynamics Control (VDC-R) with three driver-selectable settings: Normal (for daily driving, controls brakes and engine output), R-Mode (for ultimate performance, utilizes AWD torque distribution for additional vehicle stability) and Off (driver does not want the help of the system). Hill Start Assist prevents rollback when starting on an incline. Transmission 6-speed Dual Clutch Transmission with three driver-selectable modes: Normal (for maximum smoothness and efficiency), Snow (for gentler starting and shifting on slippery surfaces), and R mode (for maximum performance with fastest shifts). Fully automatic shifting or full sequential manual control via gearshift or steering wheel-mounted paddle shifters. Dual clutch design changes gears in less than 0.5 second (0.2 second in R mode). Downshift Rev Matching. Predictive pre-shift control (in R mode) based on throttle position, vehicle speed, braking and other information. Wheels and Tires 20 x 9.5" (front) and 20 x 10.5" (rear) super-lightweight forged-aluminum wheels. Exclusively developed nitrogen-filled Bridgestoneฎ RE070A high-capacity run-flat summer tires, 255/40ZRF20 97Y front and 285/35ZRF20 100Y rear. Tire Pressure Monitoring System (TPMS). Brakes Bremboฎ 4-wheel disc brakes with 4-wheel Antilock Braking System (ABS), Electronic Brakeforce Distribution and Preview Braking. Two-piece floating-rotor 15-inch front and rear discs with diamond-pattern internal ventilation. 6-piston front/4-piston rear monoblock calipers. Steering Rack-and-pinion steering with vehicle-speed-sensitive power assist. 2.6 steering-wheel turns lock-to-lock. Suspension 4-wheel independent suspension with Bilsteinฎ DampTronic system with three driver-selectable modes: Normal/Sport (for automatic electronic control of damping), Comfort (for maximum ride comfort), and R mode (engages maximum damping rate for high-performance cornering). Electronically controlled variable-rate shock absorbers. High-accuracy progressive-rate coil springs. Front double-wishbone/rear multi-link configuration with aluminum members and rigid aluminum subframes. Hollow front and rear stabilizer bars. Body/Chassis Exclusive Premium Midship platform with jig-welded hybrid unibody. Aluminum hood, trunk and door skins. Die-cast aluminum door structures. Carbon-reinforced front crossmember/radiator support. Features Exterior Wide-beam headlights with High Intensity Discharge (HID) low beams. LED taillights and brake lights. Dual heated power mirrors. Flush-mounted aluminum door handles. Body-color rear spoiler with integrated center high-mounted stop light. UV-reducing tinted glass. Audio/Navigation/Performance Monitor Digital Boseฎ audio system with AM/FM/in-dash 6-CD changer and 11 speakers including dual subwoofers. HDD Music Box system, including hard drive with 9.4 GB for audio storage. MP3, WMA and DVD audio capable. In-dash Compact Flash card reader. HDD-based GPS navigation with touch screen. Driver-configurable performance monitor, developed with Sonyฎ Polyphony and Xanavi Infomatics Corp., with graphical readouts of vehicle data and driving data displayed on a total of 11 screens. 7-inch WVGA high-resolution color-LCD display for audio, navigation and performance monitor. Interior Automatic Temperature Control (ATC). Electronic analog instrument cluster with multi-function trip computer and digital gear indicator. Power front windows with one-touch auto-up/down feature. Intelligent Key system with pushbutton start. Power door locks. Cruise control. Tilt/telescoping steering column. Bluetoothฎ Hands-free phone system with voice recognition. Seating/Appointments Leather upholstered front seats with perforated Alcantara inserts. Dual individual rear seats. Heated front seats. Leather-wrapped steering wheel and shift knob. Drilled aluminum pedals. Safety/Security Nissan Advanced Air Bag System (AABS) with dual-stage supplemental front air bags, seat belt sensors and occupant-classification sensor. Driver and front-passenger side-impact supplemental air bags and roof-mounted curtain supplemental air bags. Front seat belts with pretensioners and load limiters. Nissan Vehicle Immobilizer System. Vehicle Security System. * Japan-market features and specifications shown. |
Hey, I'm new here. From the sound of it and from several tests, it seems that it will pretty much kick anthing under the badge performance to the curb.
One super noob question though, there's no manual transmission? |
Pardon my ignorance here, but how is that they put 20x9.5 wheels front and 20x10.5 rear on an AWD car? aren't they all suppose to be the same size?
The rim width is different. More contact patch on the rears but the wheels ARE the same size... ie. 20"
Tim |
It is still a rearward bias car, so the rear wheels are USUALLY doing most of the work, until the fronts are needed. That is the beauty of the car.
Originally Posted by Torv
(Post 4167)
One super noob question though, there's no manual transmission? Ohhh its sooo much better than a traditional manual stick transmission. And don't confuse this Dual-Clutch tranny with those automatic tranny's on cars with paddle shifters. This is a true manual gear box but the the clutch is computer controlled, just like Formula 1 cars. BMW offers a similar gear box (SMG) as does VW and Audi. -Ron |
at the same time, a dual clutch transmission is very different than the BMW SMG II transmission
dual clutch actually has 2 clutches, where one is for gears 1,3,5 and the other is for 2,4,6 it's engagement is quicker than the 80milliseconds possible with the SMG II transmission |
| All times are GMT -7. The time now is 04:08 AM. |
