AMS GT-R turbos are OUT!!!
Old Jun 26, 2009 | 08:41 AM
AMS's Avatar
AMS
Former Sponsor
After a long wait and testing we finally have our turbo's ready to release to the public.
The AMS GT-R Turbo Upgrade provides stock spool up, neck snapping torque and horsepower that will transform the already mighty GT-R into a true supercar! Designed as a direct bolt on for your existing factory turbochargers, you can expect gains starting at 170whp/150wtq and up with the proper supporting mods and tuning! At full boost with race gas these turbos are capable of up to 800 horsepower!
These turbos were designed to mimic spool and the aesthetics of the factory units. To the untrained eye these two turbos looks just as quiet and unsuspecting as the stock turbos but once you hit the throttle the difference becomes very evident.
On our chassis dyno with just an AMS Turbo-Back Exhaust, boost controller, upgraded injectors and a tune we were able to take our stock GT-R safely from 434 all wheel horsepower all the way up to 610! Torque was also bumped from the stock level of 406 to a massive 581 ft lbs measured at the wheels!!! Most impressive of all, this was done on JUST 22psi and 93 OCTANE PUMP GAS!
Exclusive Features
  • Direct factory replacement with NO cutting or trimming required
  • Capable of up to 800hp depending on boost and octane level
  • 170 wheel horsepower and 150ft lbs of torque gains on just pump gas!
  • Factory like fitment, even incorporates the factory heat shielding
  • Bolts right up to the stock piping and intake system.
  • OEM look that is hard to detect
  • Utilizes machined OEM turbine and compressor housings
  • Assembled with a True Garrett GT series ball bearing center section
  • Ability to reuse the factory wastegate actuators (for increased performance add on the Forge motorsports wastegate actuators)
Specifications
  • Garrett GT Ball Bearing center section with machined OEM housings
  • Comes complete with oil and water lines for easy installation
Options
Available with Forge motorsports wastegate actuators for an additional fee
CLICK HERE TO ORDER!!!
AMS
Sep 15, 2009 08:52 AM
*Chris*
20
May 30, 2008 05:13 AM
bonzelite
Feb 28, 2007 07:26 PM
JRFT WERKS
Mar 1, 2006 06:01 PM
Jul 11, 2005 02:29 PM
