Help Needed, Much Appreciated...
Hi,
I was gonna go for the Sunline GT-Spec Front Pipe, just the pipe, my questions are: 1. Will I need to modify/alter/touch my ECU after doing this direct bolt 2. Will This alarm the sensors in anyway (check engine light/dash warnings ect. ) 3. Possible negative side effects on engine from free flow? Thanking you all in advance... Peace... http://www.nagtroc.org/w/images/6/6a...ght_pipe_2.jpg |
