Article: GTR Engine
Can anyone tell me how to do an oil change on the new GTR. It looks like a special tool is required to remove the under carriage panel . Once removed i believe you can get to the side oil reservoir. If a special tool is needed , where can i purchase it ? .
Thank you . best regards . Jacques |
Probably want to take it to the dealership to have the oil changed.
What do you know about the launch control on the GT-R?
I see you have an 06 Range Rover, have you had any problems with it? Used to have an '06 also, had to get rid of it, internal engine noise, dealer couldn't solve problem. Thanks |
| All times are GMT -7. The time now is 03:33 AM. |
